92 Chevy pickup to 86 TPI
Old Sep 6, 2006 | 12:16 PM
PWKING's Avatar
Can anyone out there help me with finding info on the swap, links and parts needed. Thanks.
Old Sep 6, 2006 | 03:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
It isn't that big a deal. The only thing that won't exactly fit from the TPI system is the TPI base, which will need the center two mount bolt holes on each side elongated (or get an '87-'89 non-Vette base). Otherwise, it's unbolt and bolt back on/in.
You should probably consider 350 knock sensor & module, and 22 lb injectors. Otherwise, that's all of the "special considerations" of the engine replacement.
Old Sep 6, 2006 | 04:12 PM
PWKING's Avatar
What about wiring and computer? I'm using a complete tpi motor.
Old Sep 6, 2006 | 06:27 PM
five7kid's Avatar
Which vehicle is getting what engine?
I assumed the '86 TPI car was getting a '92 Chevy pickup engine. If that's not the case, you're going the wrong way for this conversation to continue any farther on this Board.
stalkier
Dec 6, 2015 11:25 PM
Reborn756
Sep 4, 2015 03:42 AM
Kaweh
Aug 19, 2015 07:06 PM
Winchester1094
Aug 18, 2015 10:23 AM
Sanjay
Aug 12, 2015 03:41 PM
