350TPI to 94 LT1
Old Sep 18, 2006 | 10:47 PM
magickman's Avatar
Car: 1985 camaro iroc-z
Engine: working on it
Transmission: not sure
Axle/Gears: not sure either
350TPI to 94 LT1
I have a 1985 iroc-z which I bought and pulled out the motor which was a 350 TPI that was swapped before I bought it. The tranmission is just the 700R4 If all works out well I will becoming across a 1994 LT1 motor that I would like to swap in there. I know that I have to buy the vats module but I was wondering if the wiring harness from the old motor is still useable, would I be able to use that one? because I believe that they have an electronic control to the 4l60e. so I was just wondering if that would be at all possible. instead of spending the helashish amount of money on a new wiring harness.
Old Sep 19, 2006 | 05:46 PM
Firebat's Avatar
research and search the LTX and LSX swap boards listed above.
You have to use the LT1 wiring/computer. You don't need a VATS delete module, it can be programmed out.
Retrofitting the 700R4 to a 94-95 LT1(Read Post #2): https://www.thirdgen.org/forums/ltx-...ighlight=700r4
Old Sep 21, 2006 | 03:06 PM
magickman's Avatar
thanks firebat
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
