chev to pontiac
Old Sep 22, 2006 | 07:06 AM
surfertom's Avatar
Car: 86 Z-28
Transmission: 700-r4
chev to pontiac
any major hassels installing a chevy small block into a trans-am both tpi 85 chev motor into 87 trans-am both automatics tom
Old Sep 22, 2006 | 08:30 AM
None beyond the usual busted knuckles and so forth.
The Trans Am and the Z28 are IDENTICAL, except for some stickers and such. The motor in the TA is already a Chevy one.
Old Sep 22, 2006 | 11:06 AM
surfertom's Avatar
Car: 86 Z-28
swap
thanks for your response, what i am doing is a guy at work has the trans am with no motor but all the wireing is there. the kid down the street blew up the trans in his 85 Z-28 i bought the car for extra parts for my 86 Z-28. the 85 motor is a 305 rebuilt 2 years ago all the cylinders are in the 95 compession range. what about the ecm and prom is guess the trans-am had a 350 will the ecm from the 85 z work? tom
Old Sep 22, 2006 | 12:09 PM
They'll probably work OK at least, if not perfect.
Use the 305 injectors, or if they're not there, get a set of used stock later-model Mustang ones; the 4-hole ones, with the F0TE part number. You can pick those up all day long for $30-40 a set.
Linson
Oct 24, 2025 02:00 PM
mattcanty
Oct 12, 2015 11:08 AM
paul_huryk
Oct 1, 2015 04:27 PM
