Engine identification
Old Oct 3, 2006 | 08:25 AM
92 Heritage RS's Avatar
Car: 1992 Camaro RS Heritage
Engine: 305 TBI
Axle/Gears: 2.73 open 28 spline
Hey yall,
Is there an easy way to tell the difference between a 305 block and a 350 block visually, without having to be a numbers expert?! This pertains to blocks after 1987. Many thanks.
Old Oct 3, 2006 | 10:37 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Look for the 5.7 or 5.0 casting marks, check the casting numbers, or measure the bore.
Old Oct 3, 2006 | 07:05 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Or get a block casting number. The blocks have different bores so they won't use the same casting numbers.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
