383 or ls1
Old Oct 8, 2006 | 02:22 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
383 or ls1
looking for the easiest way to go. would like to have the swap done in a weekend. not looking to do any programing myself, so would a ls1 be better 4 me cuz it has a ecm or would a mail order chip be the way to go. price and time, with no tuning needed are important to me
Old Oct 9, 2006 | 01:15 AM
Red92RS's Avatar
Car: 1992 Camaro RS
carbed 383, everyone will tell you much easier.
Old Oct 9, 2006 | 01:24 AM
AdamsIroc-Z's Avatar
Car: 1987 Camaro Iroc-Z
Engine: Built 355 LT1 T-Trim
Transmission: T56 6 spd
Axle/Gears: 9 bolt 3.73 gears
If you're going EFI then don't expect an even remotely high horsepower application without tunning. I'd say the LS1 is the better idea since there are now plug and play harness' that anyone with even basic electrical knowledge can install and the remainder of the swap is pretty much bolt in once you have the k member. The LS1 will be much more driveable and better on gas than the 383, plus it is very upgradable in the future. To run an even compareable system on the 383 you would need to spend big money on a stand alone engine management system.
Old Oct 9, 2006 | 03:45 AM
Ironmahn's Avatar
Car: 1986 Trans Am
What are you looking to do with this vehicle after the swap? If you are starting a 383 fresh build and are looking for high horsepower, you are going to lay down some coin. The LSx swap will cost more unless you can get the original purchase of the engine cheap, but alot of peeps like em. There is no way to not tune either of those selections, no two engines are alike... there are just to many variables. Unless you know someone with a dyno.
LT1Formula
Oct 8, 2015 08:34 PM
dusterbd
Sep 29, 2015 08:40 AM
