?'s About 305 to Lt1 swap NEED HELP!
Old Oct 27, 2006 | 01:08 AM
justThen92rs's Avatar
Car: 92 Camaro RS
I have a 92rs TBI and swaping to a LT1 from a 94. I have all the wiring harness and computer Wat do u do to bypass the VATS and wat wires do i need to splice and connect to, to get the my car running??
Old Oct 27, 2006 | 12:07 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Won't run without a VATS module stock. You either need a VATS, VATS bypass module or have it programmed out of your computer. LT1 Swap has a short list of what must be connected for engine to run.
Old Oct 30, 2006 | 07:56 PM
Car: 92 Camaro RS
where could i purchase a bypass module besides the GM dealerships???
Old Oct 31, 2006 | 11:33 AM
ACCLR8N's Avatar
eBay Motors: GM VATS or PASSkey II Bypass Module For LS1 and LT1 (item 220014050176 end time Nov-02-06 10:17:57 PST) I haven't used one of these myself. Do a search on here for Bakerelectronix.
Old Oct 31, 2006 | 06:58 PM
CamaroKid89RS's Avatar
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
It would probably be easier just to have your PCM reflashed removing the VATS. It's what I would recommend. That way you can have other things removed such as EGR and AIR. You can also have shift points changed for a more agressive shift.
Old Nov 1, 2006 | 06:29 AM
ACCLR8N's Avatar
I wouldn't call it easier (or cheaper), but having the PCM reflashed is definately the better way to go. I'm saving that step for later myself until I've decided what I'm doing with the engine. Or should I say, if I have any money left for that stroker crank.
Old Nov 2, 2006 | 08:44 PM
Car: 92 Camaro RS
i need some info about connecting the LT1 wiring to my 92 rs and which wires to connect
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
