87 350tpi into 91 rs v6 need bulkhead conn wiring diagram
Old Nov 6, 2006 | 04:14 AM
tourville's Avatar
Car: 1991 Camaro RS
Transmission: 700R4 Auto
Axle/Gears: 1 legger 2.xx(needs upgrade)
have a 91 camaro rs 6 cyl put a 350 tpi, tranny, cpu, wiring harness from an 87 gta.
key is not turning on fuel pump or sending power to starter
need to know where i can find diagrams of the bulkhead connectors so i can match up what goes where thanks.
Old Nov 6, 2006 | 07:57 PM
tourville's Avatar
Car: 1991 Camaro RS
just in case anyone ever searches for this... the following website has wiring diagrams from 1982-1992 of each engine and body!!! AustinThirdGen.Org » Content » Tech Articles » 3rd-gen wiring diagrams very good website only thing it does not have is the bulkhead connector diagrams i was able to find them by searching the forums and krisb410 was able to fax me the 91 bulkhead diagram!!! very big props to him thanks a lot!!
thanks everyone for looking and hope these things help you out also
Old Sep 15, 2015 | 10:05 AM
Firechicken1991's Avatar
Car: 91 Firebird
Engine: 5.7L TPI
Re: 87 350tpi into 91 rs v6 need bulkhead conn wiring diagram
I have a 91 firebird that I swapped a 350TPI from an 88 GTA donor car...I'm having almost the same problem. Turn the key and lights and gauges come on and in my case the fuel pump also kicks on but when I turn the key the starter doesn't click or anything. I wired a push button directly to the starter and it'll fire for a few seconds and kill the fuel. Also tried bypassing the key chip using resistors. Did you ever figure out what the problem was? I'm terrible at tracing wiring and I'm out of options...any help or suggestions would be greatly appreciated! Thanks
Dark Man C
Oct 5, 2003 09:07 PM
V6camaroman
Jul 16, 2003 08:50 AM
Derek Samley
Jul 2, 2001 10:57 PM
Newbie Boy
Oct 4, 2000 08:10 AM
