lt1,ls1,or l98
Old Nov 12, 2006 | 10:27 PM
91 camaro rs's Avatar
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
lt1,ls1,or l98
which is the easiest of these swaps? Will the 4th gen(1996-1997lt1,2000ls1) motors bolt right to my 700r4 tranny and 305tbi engine mounts? will i have to change rear end gears(mine are stock, donno what they are;its a 91 camaro rs with a lo3,someone wanna let me know what my stock gearing is and what it needs to be for any or all of these swaps)will i need a new tranny or will my 700r4 work? any reccomendations(preferances) on these three would be great. also my tranny is automatic
Old Nov 13, 2006 | 11:35 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
L98 is the only bolt-in for your engine mounts and trans. LT1 adds cross member clearancing or AC delete, wiring, plumbing fabrication. LS1 doesn't even have the bosses on the block for your engine brackets. The taller your gear (numerically higher) the stronger it is. You don't "need" a gear change.
FormulasOnly
Jul 23, 2018 08:47 AM
dusterbd
Sep 29, 2015 08:40 AM
