silverado 350 in my iroc...?
Car: 1987 IROC-Z
Engine: 5.0 TPI
ok well i have a 350 block with heads from a 88 silverado..so im planing on replacing my 305 tpi with the 350...so any suggestions what heads, cam, and other goodies i can throw on it..
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
http://www.fullsizechevy.com/forums/...d.php?t=212879
what you put on it depends on your budget and intended use
Transmission: 4L80E/4L80E
Have 1.94" intake valves (and 1.60" exhaust, if you feel like it) put in your 305 heads. Do basic pocket porting (aka "bowl work"). They will out-flow those 350 truck heads in a major way.
Comp XE26x cam. The truck engine probaby doesn't have the provisions machined for roller lifters - if so, a flat tappet version with lifters is in order. If the roller provisions have been machined, it probably still have flat tappet lifters, so you'd have to get new roller lifters and proper length pushrods.
Headers are always a good goodie to do.
FormulasOnly
Sep 10, 2015 09:07 PM
