LO3 to Carbed L98
Old Oct 26, 2006 | 02:21 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
LO3 to Carbed L98
Ok, I asked for some help with this in the electronics section but didnt get too much of a response. I bought a project car that was originally an L03 car and now its got a Carbed L98 in it. The problem is nothing on the engine is wired. So I got a few schematics and tried to research what other people did for this swap but couldnt find enough info.
So my question is, what do most people do with this swap? Do they use the TBI wiring, a different wiring harness, or do they just ditch the ECM? Im lost
Thanks!
Old Oct 26, 2006 | 03:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
With the carb, the ECM is effectively ditched. You need to power the ignition and choke (assuming it has an electric choke on the carb), and wire the gages and accessories. All of that can be done with the factory TBI harness, although you might have to re-terminate a few things. With the possible exception of the choke, which may have to be powered with a new ignition-switched 12V source (there's probably an unused TBI wire that would do the job, but I have no idea what it would be).
Old Oct 26, 2006 | 06:17 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Ok thanks for clearing that up!
Old Nov 6, 2006 | 03:19 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Anyone know what year harness I need for this alternator and where I can by it? Theres 4 pins and a bat. stud on the back. Got a pic below of the alternator. And the other pic is of what I think half of the wiring harness gone, right? Ive been trying to use my 85 carbed for a reference but its just to different to get anywhere.
Attached Thumbnails LO3 to Carbed L98-dsc00881resize.jpg   LO3 to Carbed L98-dsc00882resize.jpg
Old Nov 7, 2006 | 01:57 PM
five7kid's Avatar
I know my '87 LB9 engine/harness I had used that type of connector. I assume it is all '87-up, but couldn't say beyond that.
Old Nov 7, 2006 | 03:36 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
alrighty, thanks!
Old Nov 7, 2006 | 03:48 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you swapped it to a LS1, you could get a plug and play harness from speartech.
Old Nov 7, 2006 | 05:37 PM
five7kid's Avatar
You could put on an '86 alternator and use the "old style" connectors. That makes it pretty easy - 2 wires to the plug, one wire to the battery, and a ground.
It does look like the engine harness is gone. You could look for an earlier harness if you use the earlier alternator. Compare it to your other car, I think you'll see what I mean.
Old Nov 8, 2006 | 12:19 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
hum, yea ill have to find out what is the easiest way, I got a spare 85 alternator but its not for a serpentine setup. thats for all your help guys.
Old Nov 9, 2006 | 09:58 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Ok went to advance auto and got a harness for the alternator and all is well, but got a few questions. The alternator is permenatly wired to the battery via the bat. post on the alt, but its a fused link right? what size fuse should i use?
Old Nov 12, 2006 | 08:48 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Old Nov 12, 2006 | 11:19 PM
BBCAM's Avatar
Car: 99 Camaro
Engine: LS
Transmission: TH-400
Axle/Gears: 3.25 9"
The positive post on the alternater is wired direct to the battery it only allows charging through that terminal and is not fused as the alternater is only charging when the key is on and the power to the rectifier is on , the short distance that the power travels from the battery to the alternater is not prone to shorting as long as the wire is properly positioned , also on a side note you can change pulleys on the alternaters from serp to V-style or the other way around , they just unbolt with the big nut in the pulley..
Old Nov 13, 2006 | 02:46 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
ok thank you
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
64Chief
Sep 12, 2015 08:05 AM
Stroopwafel
Sep 11, 2015 06:38 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
