tpi distributor placement and any swap tips?
Old Nov 22, 2006 | 09:59 PM
chevrunner21's Avatar
Car: 1992 trans am
Engine: 305 tpi
i spun a rod bearing and i'm swapping the motor in my trans am and i need to know how to put the distributor in the motor once it's in is it like putting a distributor in a normal small block? and are there any tips you guys might have for a novice to be swapping his first motor out and in an f-body and working on his first tpi?
I figured un plug everything pull this top end off and put this top end back on the new short block put back in and plug everything back in is there anything else i have to do? if you guys know of any sites that tell me or show me how to pull out and replace a tpi motor in my car? please help this is my daily driver and i hope to have the engine swap done in about 2 and a half days so any tips you have or like i said sites that tell and/or show me how to pull and replace the motor will help greatly. thanks for any and all information that you could possibly give me.
Damien
Old Nov 23, 2006 | 05:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The distributor is installed just like in the old days.
The engine replacement is pretty much what you said. To make the going back together easier, take photos as you take things apart, using masking tape & a marker to identify things as you take them apart, use baggies and/or cans to keep fasteners & parts straight.
Old Nov 23, 2006 | 05:43 PM
Car: 1992 trans am
Engine: 305 tpi
thanks thats what i figured and planned on doing, will all of my acessories bolt up from my stock motor? i was told it will be easier to pull the trans with the motor is this true? i was gonna pull the radiator and unbolt the hood and driveshaft drop the x-member and pull the motor and trans together is there any easier ways?
Old Nov 23, 2006 | 06:38 PM
five7kid's Avatar
It's about a 50/50 thing. Unbolting the engine from the trans is a little difficult, but the engine alone is a little easier to handle on the hoist.
Are you using the 350 or the 305 heads? In other posts, you indicated you're using the 305 heads. Almost everything bolts to the heads, and what doesn't bolts to features that haven't changed on SBCs over the years.
Old Nov 23, 2006 | 06:40 PM
Car: 1992 trans am
Engine: 305 tpi
i'm going to be using the 305 heads you've got it and thanks for all of the information that you've given me.
midge54
Jan 29, 2017 07:00 PM
Caspar
Jun 19, 2016 11:19 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
cstrobel65
Aug 15, 2015 10:19 AM
Sanjay
Aug 12, 2015 03:41 PM
