Building a 396
Old Nov 24, 2006 | 12:37 PM
FrostByte's Avatar
Building a 396
I have recently desided I would love to build a 396 and was wondering if any of you guys knew the specs as far as cranks, blocks, rods, and what not. I've never built a stroked engine before just regular 305, 350, 400, or whatever.
Old Nov 24, 2006 | 12:55 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
http://search.stores.ebay.com/chevy-...cusZbsQQsofpZ4
I just did a quick ebay search... you have a few options and NONE of them are cheap, if you would like to build a 383, those you can build for cheap(er) in comparison, you will need to use a 6.0 connecting rods or bigger and I suggest to keep every thing forged. If you want to go larger then the 396 you can go into the 400 while still keeping the 350 block, it will need alot of clearancing done either way... Good luck with the build.
Old Nov 25, 2006 | 12:44 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
396ci stroker small block, or a 396ci big block?
Old Nov 28, 2006 | 12:00 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
My long term goal is a 396 LT1. I plan to use a Callies Dragonslayer crank. 3.875" stroke vs. 3.48" stock stroke. The forged crank enables it to be internally balanced among other things. Set up for a 5.85" rod. If you are starting with a Gen1 350, they use 6.00" rods. The cranks run around $800. Haven't seen an off the shelf piston for this arrangement so expect to buy $650 worth of custom slugs. Then the whole mess has to balanced.
ZEEYAA
Apr 16, 2023 08:29 PM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Zell1luk
Sep 29, 2015 10:36 AM
Jlanz55
Sep 29, 2015 08:55 AM
