What is This Engine Piece? (84 Firebird)
Old Nov 23, 2006 | 09:31 AM
firebirdta84's Avatar
Car: 84 Trans Am
Engine: V8 305 4bbl
A buddy of mine pulled his stock 305 from his 84 Firebird and replaced it with a 350. When all was said and done, he had this piece leftover and no clue where it goes. I don't know much about engines - can someone tell me what this piece is and where it goes?
Thanks,
Joe
Old Nov 23, 2006 | 09:36 AM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
Looks like that exhaust valve that goes in on the passenger side just after the manifold. I guess it helps the engine warm up faster or something.
Old Nov 23, 2006 | 10:03 AM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
throw it in the trash.... its a butterfly valve that make the motor "warm up faster" very dumb, very useless, hurts exhaust flow.....
Old Nov 23, 2006 | 06:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Technically it's called the EFE valve for Early Fuel Evaporation. It closes when the engine is cold to route exhaust gases under the intake plenum to prevent fuel pooling until the engine warms up. It is operated via a thermal vacuum switch on the intake manifold. If the car still has the underhood vacuum diagram decal, that's what it will be called.
Some places that have strict emissions inspections will require it to be present and operating. If you don't live in such an area, you can get by without it. Technically, it's a violation of federal law to remove it.
How did he get the exhaust hooked up without it?
Old Nov 28, 2006 | 01:48 PM
fullsize fun's Avatar
Car: 1986 pontiac bonneville
Engine: LB9 305
Transmission: MK6 T5
yea it would be a good trick the reinstall the stock manifolds and y pipe without it ,that would be a helluva exhaust leak
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
