Couple of questions about my new stroker
Old Dec 7, 2006 | 10:22 PM
liquidirocz's Avatar
Car: 1986 iroc-z
Hey guys i was wondering if there would be any problem with the camaros being kinda low and installing an milodean oil pan that is made for strokers, has anyone used them? i think its a 7 or 8 quart oil pan. i"m not sure if it will fit either? Also has anyone had problems with the rearends coming out of these cars with alot of power? i have heard about it for a guy i know, but i think if i dont use sticky tires i should be fine? And i am using the 700 for the trans, and im going to put a trans kit in it, would anyone recommend anything else to do to it?
thanks, brian
Old Dec 7, 2006 | 11:05 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
you mean this one??? well i have that one and its all good.. i was dropped with sportline's and had no problems.. it was pretty hard to put in the longtubes though.. and about the rear, if its stock beware.. make sure you have good suspension pieces and LCA relocation brackets.. i had some wheelhop and blew out the spider gears on street tires.. one more thing, its really hard to tell you what to do with your car if no one has any idea what it will be used for, how mucch money you decide to spend, and what your driving style is.. elaborate a little then you will get a better answer
Old Dec 7, 2006 | 11:32 PM
Car: 1986 iroc-z
Its gonna be like a daily driver and the 1/8 track once in a while. and thanks yea its the one.
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
Mickeyruder
Sep 2, 2015 02:45 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
