Crate Motor Sugg's?
Old Dec 10, 2006 | 05:48 PM
5.7iroc-02ws6's Avatar
Car: 1988 IROC/02 WS6
Engine: zz3 crate w/12 psi ATI and stock ls1
Transmission: 700r4 w/2800 stall and m6
Axle/Gears: 3:42 10 bolt-both cars
Crate Motor Sugg's?
I have an 88 IROC.. Currently running a p1sc intercooled procharger kit (6-12 psi pending pullley) I wish to retain the TPI setup.. Have 36# inj's and ALL the bolt on TPI improvements if I recall *would have to pull the receipt* and wish to jump into a crate motor.. I like GMPP setup but prices are high... Was thinking the ZZ383 or the HT383 w/some AFR heads..
Any spec's recommended on cam profiles? I am shooting to keep Compression under 9:5 or 9:6 as well..
(don't care about emissions and I already have the chassis/rearend/tranny work all done)
Ryan
Old Dec 10, 2006 | 09:47 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
if it's a blower motor then build all forged through a local machine shop. Your compression will be dependant on what psi you're running and cam, fuel requirements, etc. I wouldn't use an out of the box crate engine for this, unless you wanted to, otherwise have a shop build a forged 383 bottom end and put whatever you want into it.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
italiano67
Dec 11, 2016 09:21 AM
Steve78LT
Feb 24, 2016 12:15 AM
masonta
Aug 31, 2015 10:14 PM
