305-350 no go
Old Dec 22, 2006 | 06:05 PM
imRICH23's Avatar
Car: 88 vert iroc & 95 586hp trans am
Engine: 355
Axle/Gears: 373
305-350 no go
i just swaped out my 305 and put in a 350 in my 86 maro. i go to do a burn-out and the car cuts off. and it wont start by itself. have to pour gas in the carb even after its been running for 10+ mins. Whats wrong?
Old Dec 22, 2006 | 06:46 PM
1320-camaro-383's Avatar
Car: 91 camaro
Engine: 383 demon 750 rpm heads 150 shot no
Transmission: bto 700r4 stage 3
Axle/Gears: currie 9" 4:10 true track
What type of fuel system do you hav?&Is it the same one as the 305?
Old Dec 23, 2006 | 12:45 AM
imRICH23's Avatar
Engine: 355
Axle/Gears: 373
BOTH WERE CARB
Old Dec 23, 2006 | 01:00 AM
DocHoliday's Avatar
Car: Red 1984 Z-28
Engine: 4.8 LS
I'm gonna say fuel pump. Does the car have a mechanical fuel pump on the passenger side of the block? Take the fuel line off the carb and put a towel under it. Now crank the car over and see if fuel comes out of the line. If not, I would bet its the mechanical fuel pump. My car had the same problem last year. Would just crank, but put fuel in it and it would turn over and then die after it burned off the fuel. If it does spit out fuel, then move up the fuel system, check your fuel filter to see if it is clogged, replace and see if the problem goes away. If not, then might be something with the carb. Possibly a rebuild at that point. But you gotta find out about the fuel pump. Post back up when you find out.
Old Dec 23, 2006 | 09:22 AM
imRICH23's Avatar
Engine: 355
Axle/Gears: 373
the fuel pump that was on the camaro engine wasnt mechanical, but when i swapped motors i had to use the mechanical fuel pump. ill do what you said then ill repost when i find out.
Old Dec 28, 2006 | 04:10 AM
DocHoliday's Avatar
Car: Red 1984 Z-28
Engine: 4.8 LS
Any info yet?
rockfourone
Dec 15, 2008 03:51 PM
smallblockking
Jan 29, 2008 09:11 PM
smallblockking
Nov 9, 2007 05:02 PM
86White_T/A305
Nov 19, 2006 09:17 PM
84 t/a 5.0
Dec 8, 2005 10:34 PM
