LT1 Motor mount question
Old Dec 23, 2006 | 10:42 PM
cybertiger130's Avatar
Car: Trans-am
I am currently replacing my stock 305 in my 1989 T/A with a 1995 350 lt1
The problem I am having is the passenger side motor mount is to far back causing to engine to set in shifted to the passenger side. i used to engine mounts off the orginial 305 engine. I seen in my service manual that are other predrill holes for the frame mount, I was not sure if i needed to move the frame mount.
thanks michael
Old Dec 28, 2006 | 12:47 PM
OddyseusDSM's Avatar
Its on the wrong holes, trust me, look a little farther forwards and you will see. You need an A/C delete pulley as well.
Old Dec 28, 2006 | 01:00 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Most likely you have the mount on the engine side bolted to the wrong holes. I attached a pic from the hpsalvage web site. It shows the proper location.
Old Dec 28, 2006 | 01:06 PM
TexasLT1's Avatar
Car: '92 RS
unless he plans to keep a/c. in which case he would have to modify the mount
Old Dec 29, 2006 | 07:17 PM
Car: Trans-am
engine mounts
Thanks guys, I moved the mount and it lined right up, it's been some time sence I removed the 305 and forgot that there a stud on one of the mount.
any thanks again.
Michael
Wesly_66
Aug 26, 2015 09:55 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
