what valve covers to use?
Old Dec 24, 2006 | 08:34 PM
mikey R's Avatar
Car: Black 89 RS
Engine: 383 ci, TBI injected, AFR heads
Transmission: TH700R4
Axle/Gears: 3.73's
Im doing a 383 with AFR heads for my 89 RS. Problem is the valve covers. I have the comp cams magnum stainless roller rockers, 1.6 ratio, 3/8" stud and of course the stock valve covers won't fit. The baffles won't clear the rockers and also rub on the bolt stands. What stock valve cover can use? what after market valve cover works? Im trying to keep it stock looking.
Old Dec 24, 2006 | 10:01 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
any "tall" valve cover should work.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
