Tpi-carb swap
Tpi-carb swap
So im just about to start my cousins swap, 305 TPI<383 conventional SBC..
What do I need to make this work?Throttle/kickdown cables?Engine and wiring harness?Gauges?
What do I need to make all this work?
Transmission: 4L80E/4L80E
There a tech article linked from the thirdgen.org homepage. Look at it first.
Throttle cables, radiator & heater hoses, some means to deliver carb-type fuel pressure instead of EFI fuel pressure.
You can use the existing harnesses. Just keep what you need - alternator, oil pressure, coolant temp, distributor power, tach lead, etc.
Hello, Michael
Aug 20, 2015 03:19 PM
