*URGENT* 350 GTA into my 305 TPI car...
Old Jan 6, 2007 | 09:53 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
It is possible that I can get my cousins 99xxx mile 350 TPI from here GTA...
I have a 305 TPI in my 92 Z28, would the swap be a lot of work?!?!?!
What is a resonable price for the 350, right now it runs strong in her GTA...
My little cousin though 700 would be a good price...
So anybodies help could be appreciated now, while I'm still talking to her.
Its not like a I don't talk to her... its just she has like 3 other buyers right now...
Old Jan 6, 2007 | 10:57 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Does the intake look similar? Chances are (I could be wrong) the only difference between the 350 TPI and the 305 TPI was the PROM chip and possable differences in the intake (trottle body dia., injectors, ect.). It will bolt right up to (as well as the wiring) your camaro.
Old Jan 6, 2007 | 11:57 PM
Skoda101's Avatar
Car: 1987 GTA
Engine: High reving 332ci monster
Axle/Gears: 3.73 posi
what year is the trans am? because if its a 89 or earlyer your going to need the wire harness and ecm aswell to drop the 350 in your camaro
Regards
Skoda
Old Jan 7, 2007 | 09:29 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Can't he still use all the hardware from the 350 and just get a 350 chip for his ECM?
Old Jan 7, 2007 | 10:07 AM
blackroc68's Avatar
you dont have to swap the wiring harness!!!!!!!!!!!!
Old Jan 7, 2007 | 11:49 AM
Skoda101's Avatar
Car: 1987 GTA
sorry for the high jack but a map's wire harness is compatible with a maf EFI
Old Jan 7, 2007 | 12:47 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
it is an 88 GTA I think, could be an 87 though...
Old Jan 7, 2007 | 02:07 PM
Skoda101's Avatar
Car: 1987 GTA
sry z2eight i'am not going to reccomend any thing further in tell I can figure out myself if the map's wire harness is compatible with the drop in 350 maf system
Regards I'll keep you posted
Skoda
Old Jan 7, 2007 | 02:35 PM
Skoda101's Avatar
Car: 1987 GTA
Hey z2eight
The link below will set you in the right direction you'll need to know on what is needed in swapping from maf to map or map to maf
http://tpiparts.net/installing_tpi_on_your_vehicle
Regards
Skoda
Old Jan 7, 2007 | 02:36 PM
Sandslot's Avatar
Car: 1987 IROC-Z Z28 Convertible
Engine: LB9
305 LG4 > 350 TPI
Although I did not do the work, my 1987 IROC has a 1989 TA 350 TPI in it. The prev owner did an entire swap (harness & powertrain) and he told me it was not a huge issue, but had to "pin-match" the IPs on the IROC. Also, even to this day, the headlight wiring has been a problem since the TA has 1/side, the camaro 2/side. the light harness swap is not straightforward.
Old Jan 7, 2007 | 04:23 PM
ACCLR8N's Avatar
Originally Posted by Skoda101
Hey z2eight
Regards
Skoda
Skoda,
Even if the 350 is MAF, my understanding is he can run it MAP with the old harness and ECM. For that matter, stick the 350 long block under the 305 intake. Swap the injectors and get a 350 chip for his ECM.
Old Jan 7, 2007 | 05:12 PM
Skoda101's Avatar
Car: 1987 GTA
Hey ACCLR8N
your right he could do that, like the aproch to (KISS)
regards
Skoda
Old Jan 7, 2007 | 07:17 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Well,
I thought it would of been a more straight forward swap... just need a 350 computer and bingo...
Besides the engine... how much in extra parts are we talking about?
Old Jan 8, 2007 | 11:53 AM
ACCLR8N's Avatar
In theory all you need is a 1992 350 chip to replace your 305 chip inside the ECM. Everything else can come from your car or the 350.
Old Jan 8, 2007 | 03:52 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Cool , where can you find 350 chips?!?!
I can't take to much from her car, she is still going to use it...
Old Jan 8, 2007 | 08:10 PM
ACCLR8N's Avatar
Lots of places. Do a search for TPI PROM. TPIParts.net Skoda mentioned has 'em for $75.
Old Jan 9, 2007 | 06:15 AM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Yea I saw them?
Do I just plug it in or what? What does it do?
Thanks, I'm a noob!
Old Jan 9, 2007 | 06:36 AM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
if you are taking the motor just take the ecm too. keep your map setup and swap injectors like was mentioned earlier. If you need any help just pm me I have done probably 3 dozen swaps so no big deal.
Old Jan 9, 2007 | 08:24 PM
ACCLR8N's Avatar
Originally Posted by Z2EIGHT
Yea I saw them?
Thanks, I'm a noob!
Yes, you unplug your 305 version and plug in the 350. There is a little cover on your ECM (computer). Its under there. It holds all the programing that based on the sensors, decides when to open the injectors and then close them again among other things.
The discussion has been revolving around not knowing what the 350 is. There are Mass Air Flow versions that use a heated wire to measure how much air is entering the motor versus Manifold Absolute Pressure (speed density) that relay on assumptions and look-up tables in lieu physically measuring how much air is entering the motor.
Old Jan 10, 2007 | 06:23 AM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
She has the same intake as mine if that matters...
Okay this dones't sound so bad....
Uh.. Do I need her wiring harness or not? and what kind of injectors do I need and why...
Old Jan 10, 2007 | 08:07 PM
ACCLR8N's Avatar
No you don't need her harness. You do need the larger injectors from the 350. The off the shelf factory PROM for a 350 assumes they are a specific size (22lb/hr?). If you use the smaller 305 injectors (19lb/hr?) your engine won't get enough gas.
If her intake has all the same sensors and connections as yours the swap gets really easy.
Old Jan 10, 2007 | 09:26 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Okay,
350 from an 88 GTA
22# Injectors, specific brand?
90-92 350 TPI PROM
Anything else?
Wait... doesn't her engine have the injectors...I can only find 21# and 24# injectors... where's her injectors?!
Old Jan 10, 2007 | 11:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Stock factory 350 injectors are 22 lb.
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
