L31 Vortec Engine into a 92 L03 RS
Old Jan 11, 2007 | 10:54 PM
TurbomanKnight's Avatar
Car: 1983 Recaro T/A
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
This weekend I will be taking delivery on a 92 Camaro RS with a L03 and 700R4. I have a Complete 5.7 Vortec in a wrecked 99 Chevy Express that I wanna put into the Camaro. What would I need to make the L31 work? And what fuel injection setup would be best?
I'll have more questions, when I remember them.
Old Jan 12, 2007 | 12:53 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Certainly not the L31 induction.
Get a TBI intake for Vortec heads. Go to the TBI forum to see what needs to be done to make it work properly on a 350. Exhaust upgrades are in order, and you'll be doing some PROM tuning.
Old Jan 12, 2007 | 12:58 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Check this out. I wrote a whole tech article on this whole swap.
https://www.thirdgen.org/forums/tbi/...i-buildup.html
Old Jan 12, 2007 | 03:28 PM
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
Fast355, Thats a really great Write up!
But I dont wanna mod the engine, I just want the Reliablity of the Vortec and it's power. If I were to drop the engine in and run it as stock, what kinda work will I have to do?
Old Jan 12, 2007 | 05:11 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
It will basically drop right in with a TBI-Vortec manifold. If you are in smog country and have to keep your EGR the GMPP intake is your only easy option. You will need larger injectors and a 350 knock sensor. You will also need a custom prom to make the combination run. To get all of the vortecs power, you will need to do something about the paper weight L03 exhaust system. It chokes a stock L03 305, much less a Vortec 350.
Old Jan 14, 2007 | 06:17 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
L31 is a great engine. I have one in my 1997 Silverado. I am considering buying an '84 T/a and building a 350 with an L31 as the clean slate.
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
