Serpentine Belt Conversion Question
Old Jan 16, 2007 | 06:56 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
So I purchased the GM serpentine belt conversion kit and it comes with the reverse rotation water pump. I want to leave my car appearing stock and did not want to convert to electric fans.
Does anyone know of a stock clutch fan set up that will work on a reverse rotation serpentine belt setup?
Thanks in advance!!
Old Jan 17, 2007 | 01:55 PM
madmatt92RS's Avatar
Car: 92 Camaro RS 25th aniversary editio
Engine: 305 tbi
Transmission: auto
you could always go with a reverse rotation flex fan bolted strait to the water pump. thats what i did on my 305 when the electric fan went out and i couldn't find an aftermarket electric fan that i liked. it looks really good too.
Old Jan 17, 2007 | 02:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Unbolt the fan from the clutch and turn it around the other way.
Old Jan 17, 2007 | 02:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Uhhh, I wouldn't recommend that. The blades would stick out closer to the radiator, and the pitch/curvature aren't right for operating in that direction.
Look at light truck serpentine setups.
Old Jan 17, 2007 | 03:01 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
S10 from 94-up would be a good bet, or electric fans...
Old Jan 18, 2007 | 07:40 PM
Comp788's Avatar
I am not sure if the clutch from a V6 would hold up or if the fans would have enough blades to cool.
Old Jan 18, 2007 | 09:55 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Old Jan 18, 2007 | 11:06 PM
Comp788's Avatar
Originally Posted by Air_Adam
I think that is what I am going to do. Anyone know the years for those setups?
Old Jan 19, 2007 | 12:11 AM
five7kid's Avatar
'88-up, from what I understand. I have a co-worker friend who has a '97 Suburban with Vortec 350, serpentine belt, and engine-driven fan.
Old Jan 19, 2007 | 03:18 AM
xpndbl3's Avatar
Car: 1984 Z28
clutch from the v6 hold up to what? the 4.3L v6 spins to 5500 rpm no problem and is basically 6/8th of a 350 anyways. If you were really worried about cooling you'd be using an electric fan and not screwing around with 1950s technology aka the water pump driven fan.
Old Jan 29, 2007 | 12:59 PM
five7kid's Avatar
FWIW, I just picked up a '95 Chevy C2500 6.5l turbo diesel. It has a serpentine belt set-up, with an engine driven fan - rotates the opposite direction as the engine. That should fit.
I would be careful about the clutch. Looking on partsamerica.com, it lists the part for the above application as "reverse rotation". Don't assume any clutch will work. Oh, it's also pricey - about $140 more than the clutch for my '84 full-sized van.
Old Jan 29, 2007 | 09:28 PM
Comp788's Avatar
five7kid,
Thanks for the help. I ended up ordering a Spal electric fan for my car. I have used them in the past and their stuff is top shelf. Was very pricy but will be great for my application. The only downside is that it draws almost 40 amps. The reason for that is it moves almost 3175 cfm of air flow. I am sure that I will not have any overheating issues.
Here is the link to what I purchased.
http://www.spalusa.com/fans/automate...s/30102130.pdf
I am waiting until they get their new design fan in. The first design only has one sealed motor. The new design due in first week of Macrh has two sealed motors. For my application I want sealed motors.
Old Jan 29, 2007 | 10:06 PM
five7kid's Avatar
Well, now people will know if they consider it.
Hope you plan on using relays with those electrics.
(Out of curiosity, how pricey is "very" pricey?)
Old Jan 29, 2007 | 10:09 PM
Comp788's Avatar
You bet I am going to use relays!
Actually I am going to use two and be able to switch on each fan seperate. One will be on a thermostacially controled switch and the other will be manual plus also tied into the AC compressor.
Well $350.00 is list. But I did not pay list.
Old Jan 30, 2011 | 08:13 PM
terrypowers's Avatar
Car: '85 Firebird Sport Coupe.
Engine: Carb 350 4bolt.
Transmission: 700R4 Auto.
Re: Serpentine Belt Conversion Question
I know this is an old post but I'll give it my two-cents. I install the GM serpentine belt kit on my '85 Firebird 350 and I went with a 17" reverse ration thermal fan clutch and fan from Flex-Lite (#5560 and 5917) which replaced the orignal V-belt fan clutch and fan but runs in reverse to match the water pump rotation.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
mustangdmurder
Aug 21, 2015 07:17 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
