Where to find a Cheap 350ci
Old Feb 27, 2007 | 01:45 PM
myfirstmaro91's Avatar
Car: 1991 RS Camaro
Engine: 3.1 Liter V6
Where's the best place to find cheap 350's. I have heard the junkyard is a good plave to look but where I live the nearest one is at least a hour or more away driving. Any other suggestions. Or should i just buy a new crate engine.
Old Feb 27, 2007 | 01:50 PM
TheDon's Avatar
Car: 1991 RS, 1986 IROC-Z
Engine: 3.1, LG4
Transmission: 700R4, 700R4
Axle/Gears: 10 Bolt, 10 Bolt
Its worth the drive. I live 2 hours away and I go every weekend. At my yard a block is $70 with heads its $120 and full motor is $200
Old Feb 27, 2007 | 02:14 PM
TheDon's Avatar
Engine: 3.1, LG4
PM sent
Old Feb 27, 2007 | 02:41 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
how i used to snag up cheap engines and such was to leave notes on ppls doors where an old van or truck or car was sitting that i knew was sbc powered and looked like it had been parked for a while
most of the time i got them for dirt cheap, 50 or 100 bucks and ended up with alot of good engines and tranies this way
for several years, but not stuff is hard to find, everything here has been hauled to the shredder within the past couple years all of a sudden
too many jobless ppl with trailers around here
and scrap prices are way up
good luck
Old Feb 27, 2007 | 03:31 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
I notice you have a 3.1 engine. On the side it says you have a limited slip. What in the world makes you think you have a limited slip?
Old Feb 27, 2007 | 05:05 PM
Car: 1991 RS Camaro
well to tell you the truth i am not sure which type of rear end i have. the only real reason i think it is a limited slip is because thats what my stepfather said it was i just sort of trusted him. I know its the stock rear end. I just don't know what type it is, or the gear ratio for that matter.
Old Feb 27, 2007 | 06:00 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Not trying to rain on your parade but the V6 cars were all open differentials and not limited slip. If you were to do a burn out it would leave only one tire mark not two. Luckly the V6 rearends usually had better rear ratios than alot of V8's but still, you do not have a limited slip.
Get the 350 you are looking for before you worry about the rear end deal. I figure I would give you my two cents in it before someone with a worse attitude tried to kick you in the ***** for it.
Good luck.
Old Feb 27, 2007 | 06:47 PM
bahsarie's Avatar
Car: 89 IROC-Z T-top C&C
you can find some on here cheap, also it depends on if you want two bolt or 4 bolt main. But i would make the trip if you were planing on doing a full rebuild, if not then maybe get a crate or find one on here.
Old Feb 27, 2007 | 06:58 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I found one locally on ebay, but craigslist had plenty too.
Also look in your local newspaper.
Old Feb 27, 2007 | 07:04 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
You can probly find one at a junkyard for 2-300, 200 for bearings and gaskets if there is nothing else wrong with it and you have a reliable 350 if you build it right.
Old Feb 27, 2007 | 07:56 PM
Car: 1991 RS Camaro
Good luck.
LOL i appreciate your care for my *****. anyways ok thanks for the info. I learned something new about my car today. which i know i have a long way to go.
Good luck.
Last edited by myfirstmaro91; Feb 27, 2007 at 07:56 PM. Reason: Automerged Doublepost
evilstuie
Apr 14, 2016 08:52 PM
GTAman
Sep 21, 2015 09:57 AM
dutch930
Sep 11, 2015 06:58 AM
Fox118
Sep 1, 2015 04:07 PM
1LE91
Aug 31, 2015 08:13 PM
