Where to find more HP
Old Mar 2, 2007 | 12:26 PM
kelham's Avatar
Car: 87 TA / 87 Firebird
Engine: 385 FastBurn / Performance 3.4L
Transmission: TKO600 / 700R4
Axle/Gears: Ford 9" / GM 10bolt
I have a 350 block, GM zz motor with fastburn heads, lt4 hot cam, 1.6 rockers, holley carb,. TKO 600 Trans, Moser 9'' w/ 3.89 gears and w/ Wilwood Brakes.
Can anyone recomend anything I can do to pick up Horsepower, I am putting 425 at the flywheel and around 405 to the wheels with 469 tq. Are there anyparts I can add such as other engine parts to pull some more power, because I dont want to run a turbo or supercharger.... + dont think I can with my compression ratio... 9.6.1
Old Mar 2, 2007 | 01:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What intake and precisely what carb?
Old Mar 3, 2007 | 01:37 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
thats only like 10% loss through drivettrain
Old Mar 12, 2007 | 01:59 PM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
5% actually, no way.
Old Mar 12, 2007 | 04:47 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
no way in hell a 9.6:1 350 is laying down more power at the wheels than my 11.2:1 385.. just over 5% drivetrain loss is but anyway, you could always throw on a 100shot.. and like five7kid said, what carb and manifold??
Old Mar 12, 2007 | 09:40 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Jeesh! Chill out people. He took a guess. What's the big deal? Hold the BS signs for a better occasion. Instead of jumping on his case (or bragging about your own car ) it would be better to share some useful information like a rule of thumb for powertrain loss.
It's fairly common to assume a 15% to 20% powertrain loss for a manual transmission. That will give you a better estimate of RWHP. It wouldn't surprise me if you are barely making 350 RWHP or less.
If you are looking to make your car faster without really changing your setup then I would work to optimize the tune of your engine and reduce weight from the car. Reducing weight from the rotating drivetrain gives extra benefit because not only do you lose the weight from the car, but the engine doesn't have to turn as much mass and can accelerate quicker. Some ideas are a light flywheel, driveline, wheels.
But my suggestion is that it is probably time to work on traction. You have quite a bit of power right now. If you can plant the tires to the ground and use that power to move the car then you will be very quick on the street. I would post questions in the suspension section of this board to learn more. Good luck!
Old Mar 15, 2007 | 07:37 AM
kelham's Avatar
Holley Carb and Intake Manifold.. and yes the car dynoed at 423 to the crank and 402 to the wheels, with 469lbs of torque. If i had a scanner I would put it on here to show it.... Oh and 5678TA its a 350 block, 385 bored and stroked, Lt4 cam, 1.6 crane rockers.
Old Mar 15, 2007 | 09:34 AM
five7kid's Avatar
Holley Carb and Intake Manifold...
Okay, what Holley carb and what Holley intake manifold?
Old Mar 15, 2007 | 12:28 PM
kelham's Avatar
Holley 750-cfm carburetor P/N 12485506
Manifold, Vortec Design Aluminum 12496820
Its a chevy manifold
Old Mar 15, 2007 | 01:05 PM
five7kid's Avatar
Ah, GM part numbers. Actually Holley and Edelbrock parts, but understand.
Did you put the engine together, or buy the crate?
That's an idle-5500 RPM intake. Fine for a mild 350, you're beyond that. You need an RPM type intake. There isn't an EGR type available, is that an issue for you?
At what RPMs were your HP and torque peaks on the dyno? You probably won't pick up peak HP, but torque would probably be higher below the peak with a double pumper carb.
You could probably get even higher peak #'s with a single plane intake. But, you'll lose some low RPM torque.
What exactly are you looking to achieve? Drag strip performance? Salt flats performance? Bragging rights?
Old Mar 16, 2007 | 07:19 AM
kelham's Avatar
EGR isnt an issue I eliminated it when I swapped engines. I built it. Im looking for drag strip performance but still streetable, ( drive a couple days a week.)
Old Mar 16, 2007 | 02:31 PM
five7kid's Avatar
That's what I do with the '57. The RPM is much, much better than the "Performer" type manifolds. I picked up better than a tenth with it over an Action+ (Performer equivilent) with the 270 cam I had before. No contest with the 282 cam (closer to the Hot Cam).
Assuming you have adequate traction, you should pick up a good bit with a 750 double pumper (you might want to consider the HP style if no choke is an acceptable situation for you - it is for me) and a Vortec RPM manifold.
A double pumper is really the preferred carb type for a manual transmission, anyway. Don't get that secondary closing delay when you back off of it like you get with VS.
Old Mar 16, 2007 | 06:57 PM
5678TA's Avatar
Car: 1984 Trans Am
i used to run a 650 thunder AVS on my first 383 and i kinda liked it.. when you floored it, it had a little kick when the secondaries opened.. like braaapBRAAAPPP
but i do like the DP style better.. dont have to wait for the power..
Old Mar 16, 2007 | 07:45 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
What makes you so sure....?
Old Mar 16, 2007 | 07:51 PM
7.0 camaro's Avatar
Car: camaro
Engine: 383
Transmission: 350 turbo
put a single plane and a go with a bigger cam.
Old Mar 16, 2007 | 10:20 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
A properly set up vac secondary wont do that
Old Mar 16, 2007 | 11:12 PM
Car: 1979 Malibu
Engine: Blown LSx
common sense????
Old Mar 17, 2007 | 04:08 AM
5678TA's Avatar
Car: 1984 Trans Am
well the carb was straight out of the box.. just a little idle mixture tuning.. it was kinda fun.. like a 25hp shot.. haha
Old Mar 17, 2007 | 12:46 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
common sense????
You have a lot to learn, young Jedi.... things are not always as they seem.
Old Mar 19, 2007 | 12:17 PM
kelham's Avatar
Try me i got the dyno sheets, just need a scanner..
423 hp @ 5400 rpms
469 tq @ 4500 rpms
Old Mar 19, 2007 | 12:23 PM
kelham's Avatar
57kid which one would you recomend more
summitracing part #
EDL-2913
or
EDL-71161
I heard that going with a double plane I will lose HP
Old Mar 19, 2007 | 12:28 PM
kelham's Avatar
5678TA I still havent seen your engine setup pics, http://www.cardomain.com/ride/2278158
Old Mar 19, 2007 | 01:51 PM
five7kid's Avatar
The Hot Cam doesn't need anything more than the RPM.
If you go with the Super Victor, you'll probably see slightly more peak HP, but you'd better never operate below 3500 RPMs (under power, that is). I don't have anything directly to back this up, but the HP cross-over between the two manifolds would probably be around 6000 RPMs. Hardly worth it, IMHO, to go with the single plane.
Old Mar 19, 2007 | 01:57 PM
5678TA's Avatar
Car: 1984 Trans Am
kelham, look at my VBGarage.. i have pics.. and a complete list of parts
ChristinaMarie
Sep 11, 2015 06:28 PM
NiG
Sep 7, 2015 11:25 PM
Street Lethal
Sep 7, 2015 01:09 PM
