please help
Old Mar 6, 2007 | 07:58 PM
patsy1's Avatar
please help
im changen a 84 camaro to a tpi engine i have a compelte 85 firebird setup what is the difference in the dash harness between the camaro and firebird i need all the help i can get with this wiring problem
Old Mar 6, 2007 | 11:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Not much. Others can chime in, but you'll need power for the in-tank electric fuel pump, which I believe is only fuses - everything else is under the hood. Hope you got all of the harnesses, sensors, and relays from the engine compartment.
