1986 305HO flywheel specs?
Old Mar 12, 2007 | 11:39 PM
waffenmacht's Avatar
Hi guys, Im new to the Chevy world, and have a simple question I'm sure some of you can easily answer. I have a 305 HO out of a 1986 Monte carlo. This is an internally balanced motor, and I need a flywheel for it. So my question is, what flywheel will fit? Which Camaro came with a 305 HO and a manual transmission?
Thanks for your help in advance
-Bruce
Old Mar 13, 2007 | 06:19 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
hi there
well being an HO makes no difference
all the 86 and up are a new design RMS, they changed to one piece design in 86, and 86-up is "external" balance/different balance than pre-86
so you need an 86 up wheel and they are pricey and not real common in the good used world anyways,
read these
http://bb.bc4x4.com/archive/index.php/t-70327.html
http://www.camaros.net/forums/showthread.php?t=19980
http://coloradok5.com/forums/showthread.php?t=152407
http://motors.search.ebay.com/chevy_...1QQsacatZ33732
http://www.nastyz28.com/sbcmenu.html
Small Block Chevy Flywheel Part Numbers
Part # DIA. Teeth Comments
3991469 14" 168 two-piece seal, internally balanced
3986394 14" 168 400 External balance, two-piece seal
10105832 14" 168 86-later, one-piece rear seal, ext. balance
14085720 12.75" 153 Lightweight (15 lbs.), nodular iron, two-piece seal, int bal
14088646 12.75" 153 86-up, Lightweight (15 lbs.), nodular iron, one-piece rear seal, ext bal
14088648 14" 168 86-up, one-piece rear seal, ext. balance
14088650 12.75" 153 86-up, one-piece rear seal, ext balance
10174482 89-up with six-speed m/t, requires starter (10455709)
Common clutch sizes are: 10.4", 11.0", and 11.85". Some flywheels are drilled for two different clutch patterns.
good luck
Old Mar 13, 2007 | 06:41 AM
Thanks Randy.
So would I be correct in assuming that any 86 up one piece RMS 305 flywheel will work? Thats sounds like a simple enough fix for me.
Old Mar 13, 2007 | 07:02 AM
ALL 305s & 350s are internally balanced; however, on the 86-up ones, because of the way the seal works and the resulting need for a perfectly round flange, the rearmost little bit of the internal balance weight, which used to be part of the flywheel flange, got moved to the flywheel.
I know that sounds weird; the motor is internally balanced, but the weight is on the flywheel. But, it's true. "Internal balance" has NOTHING WHATSOEVER to do with which side of the oil seal, or which side of the crank/flywheel junction, the weight is on.
Regardless, LEAVE THOSE WORDS OUT OF your search for a flywheel. They will do nothing but get you into trouble. Utter them, and the brains of about 99% of the hot-rodding world go instantly into vapor lock.
Randy is exactly right, any 305 flywheel for 86-up Camro/Firebird will work. The ONLY size that will fit in the ONLY stock bell housing that will fit in these cars is 12.8" outer diameter, with 153 teeth; and of course, with the smaller bolt pattern and pilot hole in the center. The ONLY clutch that will fit is the 10.4" size.
I'd recommend the lightweight flywheel listed down there. The TPI and L69 cars came with that one; the TBI and LG4 ones, with the grocery-cart rear gear, came with the heavier one, to make it easier to break the car loose from a dead stop without stalling the motor. If you have a reasonable rear gear in the car, like 3.42 or 3.73, you'll like the light one ALOT better.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
gord327
Oct 3, 2015 01:25 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
