what did you do?
Old Mar 14, 2007 | 12:32 PM
tnt_viper's Avatar
Car: 89 Camaro RS, 99 Sunfire GT
Engine: 2.8L, 2.4L
what did you do?
I have a V6 in my RS, and contemplenting a swap in the future....but forget about me. I want to know what you guys did. What motor did you swap in. how did you get it, donor car, got a motor and looked for all the random parts, did you rebuild anything or just dropped it in...thanks
Old Mar 14, 2007 | 12:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Started with a rear-ended, complete V8 donor car. Originally "just" swapped it in (I went nuts and swapped the complete dash as well because of the year differences). Later I souped up the 305, then did a complete rebuild using a 350 shortblock. Details of current configuration in sig.
Due to the f-body only uniqueness of some of the parts, a complete donor car is a good thing to have available. It can be done piecing together the parts, but it's a lot harder that way. Definitely nice to be able to see how things need to go together.
Old Mar 14, 2007 | 01:00 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
400 small block that I bought locally from a guy.
Old Mar 14, 2007 | 01:37 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
That's exactly how I did my 87 IROC project. Transplanted almost everything, except sheet metal from 91 donar's into my 87.
Good luck with your project.
Old Mar 14, 2007 | 04:52 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
First car I ever bought was a '89 Firebird with a V6 and 5-speed manual. Blew a head gasket several years later and ripped out the V6. Put in a ZZ4 crate engine with a Tremec TKO 5-speed manual and Strange 12-bolt rearend. Wanted more so I ripped out the ZZ4 and dropped in a 468 big block with TH400 auto tranny. My method was to just purchase things as I could afford it. 15 years later and I still have the car. But uh... it's still not running since I started the big block swap.
