1989 5.0 TPI . swap to a 99 votec 350? will it work?
Old Mar 27, 2007 | 01:04 PM
jcsereiko's Avatar
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
I have a 89 camaro TPI MOTOR 305. I have the chance to get a 1999 vortec 350 motor. it is from a Tahoe SUV. it is has the heads, motor and oil pan. I was wondering if my TPI stuff would fit on this vortec motor. would my pullys, edelbrock shorty headers and my TPI intake fit on this newer style motor? would it fit up to my 700r4 trans? I am new at this stuff, but I know it would be a lot cheaper to go with a 350 then putting money in this 305 TPI. pleeeease help before this motor goes to someone else.
Old Mar 27, 2007 | 02:14 PM
ljnowell's Avatar
Re: 1989 5.0 TPI . swap to a 99 votec 350? will it work?
As covered here many times before, the vortec heads will not work with the older style intake. You will need a vortec baseplate for the TPI to work. Everything else will fit just fine.
Old Mar 28, 2007 | 10:41 AM
jcsereiko's Avatar
Car: 1989 Iroc Z28
Engine: TPI 5.0
Axle/Gears: Stock
sorry brother I am new to the site. when you say a vortec base plate, will that change my setup to something else like a carb? or is there a TPI baseplate for the vortec? also, wher do I get a TPI baseplate for a vortec 99 motor if that is all I need
Old Mar 28, 2007 | 11:39 AM
ljnowell's Avatar
I'm sure one of our board sponsors probably sells one. GMPP may have one. A web search should locate that. YOu will need some other stuff too. DO a search for 305 to 350 swaps in the TPI forum, they will have the low down for you.
Frozer!!!
Jan 19, 2024 04:55 PM
NBrehm
Aug 25, 2015 11:49 PM
jharrison5
Aug 19, 2015 05:53 PM
kyleb24
Aug 15, 2015 08:24 AM
