350 to 454 swap
Old Apr 9, 2007 | 11:07 AM
camaro_man's Avatar
Car: 92 Z28 camaro
Engine: 406 stroker
Transmission: built T350
Axle/Gears: 4.10's
350 to 454 swap
iv got a 92 Z28 with the 5.7L im upgrading to a 454 full built ready to go motor. just wanted to know the best trany, drive shaft, and rear end to swap out and replace to hold up to this monster. any help will be great.
Old Apr 9, 2007 | 01:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 350 to 454 swap
You can leave everything stock for now and replace stuff if it ever breaks.
If you do want to upgrade to something stronger, TH400 tranny, A bolt in 9" or 12 bolt differential, a 3" steel driveshaft with 1350 u-joints will be more than strong enough although will also be overkill for a stock engine even if it's a BBC.
Any BBC has lots of potential to make lots of hp and torque but in relatively stock trim, a lot of mild SBC engines can out perform it.
What kind of power levels does this 454 have? You'll also need to install SFC. Headers for a BBC swap are not cheap and the cheaper ones are not exactly a direct fit. A tubular, adjustable torque arm should be installed as well as an aftermarket panhard bar, LCA and LCA relocation brackets.
Old Apr 9, 2007 | 09:02 PM
camaro_man's Avatar
Car: 92 Z28 camaro
Engine: 406 stroker
Axle/Gears: 4.10's
Re: 350 to 454 swap
well its a 454 stroked with forged pistons. cam. 80lbs injectos, headers, decked. the works. said to be pushing about 500+ right now.
Old Apr 12, 2007 | 02:31 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: 350 to 454 swap
How about some more details? What is thestroke? Compression, cam, heads, induction, etc/...
Old Apr 13, 2007 | 06:11 PM
bb454camaro's Avatar
Re: 350 to 454 swap
what kind of computer set-up are you running?
MustangBeater20
Oct 29, 2022 09:20 PM
Fast355
Dec 2, 2016 06:33 PM
sreZ28
Aug 14, 2015 07:48 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
