Help with motor suffix TRA
Old Apr 13, 2007 | 06:19 PM
footjoy's Avatar
Can anybody help me id this motor? I know it is a 350 built in december 88 but what did it come out of?
Front pad shows V1212TRA the TRA is what I would like to know. It is not camaro engine. vin on pad is CKV 135479
thanks
fj
Old Apr 13, 2007 | 08:37 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Help with motor suffix TRA
It's not a 350 since it shouldn't have a 4" bore
V = Flint engine plant
1212 = Dec 12
TRA = 1972 307. Originally had a manual transmission. Rated at 135 hp with a 2 barrel. Came in C10 and C20 trucks.
It's a boat anchor with no rebuildable performance value.
Old Apr 13, 2007 | 09:13 PM
footjoy's Avatar
I would agree with you except the block casting is 14093638 build date is 88 I was just trying to figure out what it was out of.
Sorry I should have given that info in the beginning My list stop at around 1982
fj
Old Apr 15, 2007 | 11:05 AM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Awww, c'mon...... there's a LITTLE value!
It's a better starting point than the non-roller 305 block...
Old Apr 15, 2007 | 11:42 AM
footjoy's Avatar
I pulled the heads off last night it is a 350 4.030 bore with the roller tray pads and holes in the lifter valley. I guess it doesn't matter where it started life just where it is today.
fj
Old Apr 15, 2007 | 12:11 PM
AlkyIROC's Avatar
Car: 87 IROC L98
14093638...350...87-95...2 or 4...Roller or flat tappet cam, one-piece rear seal
TRA - 1989 350 Chev/GMC truck. 210 HP, L05 TBI
Old Apr 15, 2007 | 12:59 PM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
that is the same block i have where did you find the tra marking?
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
