Need help on a project
Old Apr 24, 2007 | 11:51 AM
87_firebird's Avatar
Car: rebuilding a 1987 Firebird
Engine: 350 nuttin to special
Transmission: looking for a 6 speed
Ok i had a 305 and poeple were saying 350s have more horsepower and you would spend the same on the 305 as you would for a 350. So i am doing a paper for school and researching this topic. Anybody would like to help me out just answer a few questions for me. thanks Jon
1. Do you have a 305 or 350?
2. Mostly stock or mostly aftermarket parts?(if a/m what is upgraded on it?)
3. Horsepower and torque?
4. How much did you spend?
and if you want add anymore info that you want to about your engine.
Old Apr 25, 2007 | 12:20 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
1. Had 305, now a 350.
2. Mostly GM parts with some aftermarket rebuild (pistons, rings, bearings). Except the heads are aftermarket. Exhaust is entirely aftermarket.
3. ~365-375 HP, torque unknown (probably around 400 lb-ft peak).
4. ~$2200 in the engine. Another $1200 or so in the exhaust. About $500 in the transmission (sweetheart deals).
For comparison, the 305 had the same stuff except for cam. It had about 300 HP, spent about $1100 of the $2200 figure of the 350, and $750 of the exhaust on the 305. The tranny had the converter ($135 of the $500) behind the 305.
Old Apr 25, 2007 | 10:00 PM
Re: Need help on a project
thanks for the reply
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
Vincent135
Sep 28, 2015 10:50 PM
