BBC Hood clearance
Old Apr 28, 2007 | 08:29 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
BBC Hood clearance
BBC owners, what intake, carb, spacers, etc.. are you running? What hood, cowl, how tall? What size air cleaner?
Just trying to get an idea before mine gets droped in.
Old Apr 28, 2007 | 06:53 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: BBC Hood clearance
My carbs sit above the hood
Old Apr 28, 2007 | 08:04 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I have had a performer rpm and 850 demon with a moroso drop base 3 inch filter under a three inch cowl hood, also a Team G fit in the same space.
Currently I have a glastek 4.5 inch cowl and a dart 4500 intake with a king demon...I have not found a filter to fit it yet, I`m thinking the UNI dominator is my only chance, I have about 1.5-1.75 inches above the air-horn.
Old Apr 29, 2007 | 11:50 AM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
A guy by the name of chev496 said he uses a (low profile?) Victor Jr. and a drop base filter. He said it cleared under his hood. He implied it was a stock hood but didnt actually say it so im not sure.
The lower the intake, the more you limit your high rpm Hp basically.
Old Apr 29, 2007 | 12:17 PM
AlkyIROC's Avatar
Car: 87 IROC L98
And a street car doesn't need to go above 5000 rpm. A race car will spin up to at least 6800 rpm to make the most of it's power. A street engine, although it may occasionally spin that high, normally operates well below 5000. An intake that starts to build power at 3000+ rpm isn't a good street intake. A low profile, dual plane intake is a better street intake or even an occasional street/strip.
Old Apr 30, 2007 | 09:42 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
I agree. I love low end torque. I thought of the idea of a 427 bbc under the hood of my car just for all the low end torque I'd have. As long as I could squeeze it under no more than a 2" cowl.
I only ever drive on the street anyway, with maybe a few nights at the strip, and I think a 450 HP 427 would be alot more fun than a 450Hp 383. Though I'm sure a 450 Hp 383 would still be pretty damn fun.
Old May 1, 2007 | 11:31 AM
Car: 1971 Camaro
Engine: 427
Thanks, I have a Victor 454 O coming, 1050 dominator. Have a Jongblod Hood. Nitrous plate. Doubt I will be able to fit a conventional filter on it. I have a couple flat K$N's I might try to make work in the hood, somehow..
Stephen, just looking at your specs, whats to lobe seperation on your cam? It is similer spec as mine.
Last edited by Johnny Blaze; May 1, 2007 at 11:33 AM. Reason: Automerged Doublepost
Old May 1, 2007 | 08:05 PM
AlkyIROC's Avatar
Car: 87 IROC L98
LSA is 112*. It idles very smooth. Big cams like this don't need a small LSA angle. ProStock cams are usually 114*
Old May 3, 2007 | 08:34 AM
Car: 1971 Camaro
Engine: 427
Anyone else?
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
mr z28
Dec 14, 2015 05:14 PM
IROCTheHouse
Oct 26, 2015 02:35 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
