vortec engine info
Old May 10, 2007 | 04:23 PM
ahall8's Avatar
vortec engine info
Hello,
I am new to this forum but I though you guys would have some info for me. I have a chance to get a 2000 5.7 vortec dirt cheap. But this is not going in a hot rod I am a demo derby driver. Would there be a problem putting an older style head on a vortec bloc? I know generally it is done the other way around but it allows me to sell the higher dollar vortec heads and not buy a new intake. Also are there any benefits to the vortec block over an 80's 350 block. Any help is appreciated.
Thanks,
Adam
Old May 10, 2007 | 07:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome to thirdgen.org.
I believe 2000 Vortecs are of the LSx family. Therefore, no compatibility with Gen I SBC's at all.
Seems like a waste of good hardware. Hope you're not going to say your derby car is a 3rd gen.
Old May 10, 2007 | 08:48 PM
ahall8's Avatar
Re: vortec engine info
thanks for the response five7kid no my derby car is not a 3rd gen. I see that edelbrock makes intakes so that you can put a carb on a vortec motor. Is that just for 97-00 or something? I see no reason to not pick up the motor for a $100. I was just wondering if I could bolt older heads onto it and let someone else get some use out of the heads. They are roller motors so a little expense for my needs, but if I can't get more out of it than a gen 1 350 I might as well use it. The roller motor should handle heat better I would think.
Old May 10, 2007 | 10:11 PM
five7kid's Avatar
You're probably right, I'm a little hazy on what the exact years of the "old school" Vortec engines were.
Old school heads will bolt to the L31 Vortec block.
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
