Flywheel question for 350 swap
Old May 17, 2007 | 03:15 PM
Alphius's Avatar
Car: '84 Z28
Engine: '02 LS1
Transmission: '02 T56
Axle/Gears: LS1 10-bolt 3.73 w/Auburn Pro
I have an 84 L69 5-speed Camaro with no motor. I bought an 81 Suburban the other day for the 350 in it. I have no flywheel/clutch parts from the L69, just the T5 and bellhousing. Will the flywheel from the 4-speed Suburban fit into the T5's bellhousing? I am getting a whole new clutch kit.
I don't think it'll work, but I'm just making sure. From my research, a 3rd gen uses a 10.4" 153-tooth flywheel, while the Suburban uses a bigger (12"?) flywheel with 168 teeth that won't fit the bellhousing.
If I'm wrong, please tell me, but I think I'm gonna hafta score a 153-tooth 10.4" flywheel.
Old May 17, 2007 | 03:52 PM
spacgost79's Avatar
Car: 88 iroc-z
Engine: 5.7 zz4
Transmission: megaraptor 700r4
Axle/Gears: 3.73 10 bolt posi
Re: Flywheel question for 350 swap
you are correct the large flywheel/pressplate setup wont fit........if you want to put the biggest clutch that will fit, mcleod makes a kit to put an 11" disk on a 153 tooth flywheel that should fit because it uses a modifide 10.5" press plate
Old May 18, 2007 | 12:13 AM
lincolnpark773's Avatar
You will also need the starter from the original Camaro with the bolts opposite each other (153 tooth style) as opposed to staggered (168 tooth style). You cannot use a early version 153 tooth style starter because the nose is too thick and will not fit in the bell housing of the T5.
Believe it or not the original starter fit on a big block and would also still fit in the T5.
Last edited by lincolnpark773; May 18, 2007 at 12:16 AM. Reason: Automerged Doublepost
Old May 18, 2007 | 04:30 PM
83-84z28's Avatar
Car: 1983 z28
Engine: '73 4-bolt 350
Transmission: t5
Axle/Gears: 3.42 with auburn and 28 spline axle
if i take my flywheel from my lg4 i should be able to bolt it right up to my also 2-piece rear main seal 350 right ?\
Old May 18, 2007 | 05:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That is correct.
Old May 19, 2007 | 12:46 AM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
Great thanks that helps as i swap my engine
Old May 19, 2007 | 08:26 AM
Alphius's Avatar
Car: '84 Z28
Engine: '02 LS1
Thanks, good info. I do have a 153-tooth starter that looks fairly new that was on the back floorboard when I got the car, so I'm set if I grab a flywheel too.
Old May 19, 2007 | 10:28 AM
At the time I was putting a 73 400sbc in my 84TA. The guy at the auto parts store told me the 84-305 starter was metric and the 73-400 was standard (English).
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
bellez77
Sep 5, 2015 08:39 PM
redmaroz
Aug 16, 2015 11:40 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
