Displacement on Demand (Chevy's version of Cadillac's Northstar)
Old May 20, 2007 | 06:25 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Has anyone thought of doing a swap with one of the newer chevy motors that runs the displacement on demand or even maybe used a cadillac motor with the Northstar System on it? You know, the engines that shut the cylinders off when it senses it doesn't need them. I think I could really handle 300hp and 30mph on the highway.
Old May 20, 2007 | 09:15 PM
B-Holly's Avatar
Re: Displacement on Demand (Chevy's version of Cadillac's Northstar)
i think the hardest part would be getting the ECU to work. Especially with the caddy motors because of all the other crap that the ECU has in it for nav, and climate control.
Old May 20, 2007 | 10:29 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
yea, my dad has a newer 2000 sumin nother cadilac and let me tell ya, i would not wont to be the guy thats trys to put that nortstar in a 3rd gen. man that thing is loaded with wires, bells, whistles, and other little doodads. i tell ya what though that thing is slicker than snot on a doorknob, and pretty quick ta boot.
Old May 20, 2007 | 10:55 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
A good LS1 with a 6-speed and 3.23 gears will get close to this on the highway.
I just checked mine again for fun with the LT1 and got 22 running the **** out of it around town, shifting at 3500-4000 rpm with 3.70 gears. If I baby it around shifting slow, I can get up near 25-26 on the highway.
Old May 21, 2007 | 01:59 PM
Ozz1967's Avatar
Car: 1984 Trans Am
My 84 Carbed 305 gets 22 on the highway with a 700R4 and 3.73 rear gears and 17 or so in town. Running it easy. I'm sure if I swapped down to 3.42 or 3.23 I could run up around 26 or so...and I might just do that. Especially with gas hovering at $3.40 a gallon here. Sure, it'll run me the cost of the gears now but over the summer I'll probably make up the difference in the cost of gas.
Old May 21, 2007 | 02:03 PM
jgetti's Avatar
I'm pretty sure it can be done. there are various companies out there that you can send your donor engine's computer to, and they'll disable/modify systems that need to be disabled/modified for your swap application.
Here's a link to an article that speaks to swapping 3rd/4th gen Chevy engines into classic trucks:
http://www.classicperform.com/tech_a...ngine-Swap.htm
In there, it speaks to sending your computer off to get it modified. This article doesn't speak specifically to displacement-on-demand, but if you contact one of the companies that does these mods, you could probably find out pretty quickly.
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
3rdgenparts
May 21, 2016 11:50 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
z28venezuela
Oct 24, 2015 08:15 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
