gasket question
Old May 30, 2007 | 01:08 PM
MR83ta's Avatar
Car: '83 T/A 2003 Grand Am Gt (built)
Axle/Gears: 3.73 posi
gasket question
im swapping in a 350 for a 305, the heads on my 305 are almost brand new, with new springs, lifters, hardened rods and everything else. Im going to use my 305 heads, should i get a 305 head gasket or a 350head gasket?
Old May 30, 2007 | 01:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: gasket question
305 block, 305 gasket.
350 block, 350 gasket.
Old May 30, 2007 | 01:22 PM
MR83ta's Avatar
Re: gasket question
k thanks thats what i thought i just wanted to make sure
Old May 30, 2007 | 01:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: gasket question
The head gasket bore has to be at least the bore of the cylinder. You could use a 350 gasket on a 305 block, but you'd be giving up some compression.
1992 Trans Am
May 10, 2023 07:19 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
redmaroz
Aug 16, 2015 11:40 PM
