Small Block to Big Block 87 Iroc
Car: 87 IROC
Engine: GM 350 soon to be supercharged
Transmission: tko 600
Axle/Gears: 3:73
Are the motor Mounts the in the same place? its a 496 bb ...........any other problems i may encounter header clearence? clearence with the radiator and electric fans ?????
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Small Block to Big Block 87 Iroc
The SBC and BBC mount locations on the block are the same. The BBC is a longer block. The extra length goes forward since the transmission doesn't move it's location. Motor mounts don't interfere with headers. It will get tight between the rad and the water pump. It depends what fan system you use. It depends what water pump you use. When I still ran a stock rad with the dual electric fans, a short water pump with electric drive was about 1/2" from one of the fan motors.
Car: 87 IROC
Axle/Gears: 3:73
thank you ! what size radiator is appropriate 3 row? alum reg ? will that give enough room for fans? figure ill guess the problems before i run into them during the install
theshackle
Mar 5, 2017 06:37 PM
mustangman65_79
Aug 11, 2015 03:17 PM
