1970's Block
Old Jun 7, 2007 | 09:49 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
1970's Block
I just got a 1970's 350. I want to drop this in my 1992 camaro rs 3.1. Will that old of a block be more complicated?
Old Jun 7, 2007 | 10:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 1970's Block
Not terribly complicated. Most things are the same as any other V8. The dipstick tube will be on the drivers side instead of the passenger side like it was with factory V8s used in thirdgens.
Old Jun 8, 2007 | 03:09 PM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
Re: 1970's Block
My block is a 1974. All of my accessories from my 1988 bolted right on (alt, a/c, p/s). I did have to drill and tap two bolt holes on the left and right side of the crank for the brackets. The bosses were there, they just weren't tapped.
The dip stick tube is on the opposite side. This was a problem because my factory manifold blocked it. Once I did headers, I bought a flexible dip tube, and everything is cool.
Old Jun 8, 2007 | 03:26 PM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
Re: 1970's Block
What about the sensors and whatnot?
Old Jun 8, 2007 | 03:39 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 1970's Block
What about them?
Old Jun 8, 2007 | 09:20 PM
SC88's Avatar
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
Re: 1970's Block
All sensors bolt on. I did not have an issue with the sensors.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
