what crate motor?
Car: 1988 firbird formula
Engine: 5.7l pony eater
Axle/Gears: 4.10
what crate motor?
hey guys i have an 88 trans am with a 350 tpi motor... just hit 202k and needs replacing. i want to get a crate motor but am unsure as to what one? i want to keep the EFI setup and want this swap to be as painless as posible. so i guess what im looking for is as close to the stock motor as posible. if you can point me in the right direction id appreciate it. vortec would be fine also, just have to change base plate. money limit is aroun 2200. Thank you
here is the vin if it helps:1G2FS2183JL240314
Transmission: 4L80E/4L80E
$2200 isn't going to get you much.
I don't know what your definition of "crate motor" is, but if you mean something you can bolt in, try these guys http://www.rebuilt-auto-engines.com/...07107168238.69 . They'll upgrade the cam if you like, $2200 should about cover it.
Axle/Gears: 4.10
Re: what crate motor?
welp, a motor with warentee is what i was looking for, has anyone here delt with these people? i dont want a crapily built motor that will not last me 30 days
My brother got that engine from them 3 years ago to put in his '92 C1500 to replace his worn-out LO5. Hasn't had a lick of trouble with it. Was pleased with the way they dealt with him - he ordered on line, they called to make sure he was asking for something that would work for him, he specifically asked for 083 heads (at my suggestion), which is what they delivered. After they were satisfied he wasn't going to be disappointed, they built it and had it in his driveway in about a week (they don't assemble until the engine is ordered).
Who you calling a "welp"????
Axle/Gears: 4.10
sory about the welp, was supposed to be well, ...... anyway thanks for your input. i will probably go with them. i have diffrent heads to slap on it and cam, but i was looking at the vortec crate motor from summitt will go over my budget but o well that is the name of the game
Axle/Gears: 4.10
gave up on warentte idea... they are stock heads that i had a port and polish done, and larger valves installed. also have a cam kit from summitt that i wanted to install. ill give that first companny a call shortly. hopefully they can hook me up
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
