swap question
Old Jun 21, 2007 | 12:42 PM
shootryan's Avatar
Car: 85 Chevy Camaro
Engine: 383/holley carb/edelbrok intake
swap question
i was wondering if i could put a 454 (and all components with it) would fit in my 85 firebird. everything is comming out of an 77 GMC suburban 2500. let me know any suggestions or precautions
Old Jun 21, 2007 | 12:49 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: swap question
sure oyu can do anything if you have the money and parts and ambition to
454 in the 70s is just a smogger low horsepower engine not hardly any more horses than a small block of the same era
no real point unless oyure going to improve it
or maybe you just like to spend even more on gas
exhaust will be the biggest headache
hope you are prepared
i wouldnt go for it unless you knew FOR SURE you could do it and finish it
or you will be sorry in the end
whats wrong with the 3/4 ton burb ?
where is it ?
hate to see another good old truck get taken apart unless its wrecked badly or something else bad
good luck
Old Jun 21, 2007 | 01:05 PM
shootryan's Avatar
Re: swap question
the "burban" is in st louis mo. nothing wrong with it, so im told atleast, but they are just in need of the money.
off topic, but would a 2.8 starter work for a 305. im also looking at another 85 bird that has a rebuilt motor. says it just needs a starter. so, i planed on starting and driving it before buying.
Old Jun 21, 2007 | 01:46 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: swap question
i beleive this is covered in a sticky somewhere. But yes, exhaust will be your biggest issue. You may have to "trim" some of your front subframe, just below the firewall area.
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
