TPI swap Question
Old Jul 3, 2007 | 01:01 PM
cam383's Avatar
Car: 89 and 91 Camaro RS
Engine: 350ci TPI and 305ci TBI
Axle/Gears: 2.73 One-wheel wonder
TPI swap Question
Hello,
Some of you may have seen a few of my posts around so far but if not here's my situation.
I have bought an 89 RS Roller (very little rust) and Have a 350 Longblock out of a 92 suburban. I am looking to set this up as a TPI and have a few questions that I have not been able to find complete answers to.
1. Is the TPI engine wiring harness still capable of going through the kick panel on the passenger side quarter panel? I have read that the TPI harness goes through the firewall by the driver side.
If this is so then..
2. Do i need to get an interior harness to jump from the driver side to the passenger side where the ECM will be or ..?
3. I know a while back when I was looking at doing an engine swap in my 90 RS it was debatable if the engine and trans could "shoehorned" in together. Is there enough room to assemble the engine and trans out side of the car and put them both in at the same time?
Thanks for any input everyone.
Old Jul 5, 2007 | 02:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
1. All ECM harnesses, regardless of engine, induction, etc., go through the passenger kick panel. The stuff on the driver's side is common to all configurations, which is the only reason it is ever brought up.
2. Not so, see #1.
3. You'll have to leave the plenum & runners off of the engine, but otherwise you can stab the engine/transmission together.
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
Sanjay
Aug 12, 2015 03:41 PM
