Fuel Pump Question?
Old Jul 11, 2007 | 10:52 AM
ChampionN84's Avatar
Car: 91 Camaro Z28
Fuel Pump Question?
I am doing a TPI Switch into a TBI Car.. I know i need to change the fuel pump but do i need to keep the hoses on the top. I never change a electrical fuel pump before i know i need to drop the tank but what else is needed for the switch. Also there is a senser on in the middle part of the rear of the car that hooks to the tank.. How do i run this? What is the part number i need? Anything guys!
Old Jul 11, 2007 | 11:41 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The fuel pump change procedure is exactly the same as it would be if you were changing the pump for TBI, just use a pump intended for TPI instead.
The only sensor I know of is the gas gage sender. The fuel pump mounts in the same bracket in which the sender is located.
Old Jul 11, 2007 | 12:50 PM
Car: 91 Camaro Z28
Re: Fuel Pump Question?
the senser i am talking about the wire goes through the car from the dash to the center of the rear seats. Through the floor and into the tank.. I am guessing your right about the gauge senser? Do i have to splice any wires to get it to work?
Old Jul 11, 2007 | 05:25 PM
five7kid's Avatar
Not if it's working now.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
