73' sbc to a 89' tbi
Old Jul 11, 2007 | 12:58 AM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
im picking up a 350 to drop in my car sometime this week. i wont be putting it in my car for a while b/c i need to buy a lot of stuff for it to work right in my car. im getting it from my friends dad so i trust him. he told me it had 260 hp from the factory and he knows that b/c someone looked up the casting or w/e for him. it is a four bolt also so it was out of a truck. my question for starters is will my 305 manifold and tbi system work on this 350. he told me the 350 was a shortblock so it wont work but im just making sure. i plan on switching to carb anyways if it doesn't work. whats a good carb/intake combo that would be good for the street with decent power. i was thinking a 650 holley would be good but i have no idea about intakes honestly. i dont have any emmision stuff on my engine right now except for egr...how do i get rid of that? i have headers and full exhaust already so im not worried about that but what else do i need to put it in my car? fuel pressure regulator i know about but thats about it.
Old Jul 11, 2007 | 12:59 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 73' sbc to a 89' tbi
Everything on your engine will fit that shortblock, except the flexplate and the oil dipstick. If you keep the TBI though, a few things like the knock sensor should be changed for the 350.
Old Jul 11, 2007 | 01:01 AM
gray89vert's Avatar
Engine: 305 TBI LO3
your sure my intake will work. it doesn't matter that its a shortblock? thanks for the quick response
Old Jul 11, 2007 | 01:03 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A shortblock is just a block with a rotating assembly in it. Basically an engine with no heads or anything above the block.
Old Jul 11, 2007 | 01:05 AM
gray89vert's Avatar
Engine: 305 TBI LO3
oh ok. lol. well it has heads on it and a manifold. will my manifold work with these heads then?
Old Jul 11, 2007 | 01:08 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's not a short block then, that's a long block. The center bolt holes on your intake are at a different angle, but you can elongate the holes to make them fit those heads.
Old Jul 11, 2007 | 01:11 AM
gray89vert's Avatar
Engine: 305 TBI LO3
alright thanks for the help. so all i need is a FPR and im all set?
Old Jul 11, 2007 | 01:27 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
For the TBI, or for the carb?
Old Jul 11, 2007 | 02:51 AM
gray89vert's Avatar
Engine: 305 TBI LO3
for the carb. idk why i even said that since im keepin my tbi for a while. so how do i go about enlongating the holes in my manifold or w/e?
Old Jul 11, 2007 | 10:55 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you're going carb then you don't need to worry about the TBI manifold, just get a carb manifold for the earlier intake bolt pattern.
Old Jul 11, 2007 | 02:27 PM
gray89vert's Avatar
Engine: 305 TBI LO3
well i was gonna use my tbi setup for a while until i get some money for a nice carb and intake. so how do i enlongate my manifold holes or w/e?
Old Jul 11, 2007 | 05:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
With a drill bit and/or round file. You may be able to find a machine shop with enough moxie to do it for you.
codeysabatini
Nov 10, 2015 04:07 PM
BLK87Z
Sep 18, 2015 11:29 PM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
