350 cam suggestions??
Old Jul 22, 2007 | 01:15 AM
blue82_z28's Avatar
Car: 1982 Camaro Z28 w/ RS groundfx
Transmission: Tranzparts 700r4
Axle/Gears: 3.23's
i've got a late 70's 4 bolt main 350. i'm looking to make at least 300 horse. the engine is going to have hypereutectic flat top pistons with 4 valve reliefs, a stock crank, 600 holley (for now), and stock ported heads, i forget what the casting numbers are. but since the cam was missing an entire lobe, it needs to be replaced, so i want something that's a little lopey and can bring me into the 300 horsepower range.
Old Jul 23, 2007 | 11:06 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 350 cam suggestions??
Five7's reply in your thread in the tech/general engine forum was a good one. Try not to make duplicate threads, it can get confusing.
The tech/general engine forum is a bit more busy than the engine swap forum, so lets just stick with that one, it's more suited to this type of thread anyway.
theshackle
Sep 17, 2020 08:26 AM
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
theshackle
Aug 22, 2015 06:52 PM
