power steering v-6 to v-8
Car: 1989 RS camaro
Engine: 350Ci
Transmission: TH-350
im upgrading from a v-6 to a 350 i was seeing if the power steering would still work from the v-6 and also is there anyone not running power steering is it hard to turn the wheel?
Car: '91 RS
Engine: 5.0L gross *** tbi
Re: power steering v-6 to v-8
now power steering would suck....of course it will be hard to turn the wheel.. im pretty sure there the same
im sure other ppl will chime in
Car: 1989 Firebird
Engine: 5.7 LS1
I'm not sure if its the same but I know that some of the ws6 or z28's had quick ratio boxes that makes the wheel turns shorter for the same turn. If you go to no power steering you need to replace the steering box, its not the same as the power box.
Non power steering is fine going down the road, but turning in the parking lot you will need some strength. Depending on your wheel size of course.
It may be easier to go to a GM dealer and see if the parts are the same between a v6 car and a non WS6 or Z28 V8 car.
Transmission: 4L80E/4L80E
Steering gears are the same (although some "better" ones came on some V8 cars, as mentioned). Pumps are the same. Reservoir, pulleys, brackets, and hoses are different.
Squeaky8791
Feb 5, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
