Hydralic roller lifters...
Old Aug 24, 2007 | 02:03 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
how high of a horsepower range can hyd rollers be used to in a mainly street car and still be reliable. I don't really want to run mech lifters because of having to reset lash all the time. But I am planning on around 600-750 hp and around 650 ft/lbs. Could I use say the 3.1L lifters or even aftermarket hyd rollers (comp,crane, crower) and not have to really worry about one of them failing.
Old Aug 24, 2007 | 02:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Hydralic roller lifters...
About 6500 would be the practical limit, maybe a little more with a rev kit. Failure isn't the issue, they're just subject to the same high RPM limits as all hydraulic lifters.
Old Aug 24, 2007 | 05:11 PM
jstoltz's Avatar
so the 3.1 lifters should be ok? I want to just build something decent and somewhat cheap. I was thinking the Dart Pro 1 heads and eagle 4340 crank and rods and either srp or JE pistons. hoping for around 600 horse. should they be. it will be a 421 so it won't rev to high anyway. 6500 shold be about max limit.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
