1969 383 in a 91 RS??
I have a 350 4-bolt main out of a 1969 Impala. I am planning to make this engine into a 383 stroker. I was wondering if the engine mounts would match up correctly. I will be bolting the 383 up to a 700-R4 transmission. In addition, I am planning to put a 750 Holly Double Pumper on the manifold. Will I need to buy a special type of wiring harness to ensure the carburetor will work?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 1969 383 in a 91 RS??
The engine mounts are the same, but the flexplate is different because of the change in the rear main seal.
Transmission: 4L80E/4L80E
You don't need a "special" harness, but you will need to modify what you've got slightly.
Thanks for all your replies; I just have a couple more questions. What is the best type of flywheel (brand) and what modifications should I do to the wiring harness?
Thanks again
Thanks again
LT1Formula
Oct 8, 2015 08:34 PM
