olds engine in a f body bird
Old Aug 25, 2007 | 07:11 PM
lilearlus's Avatar
do any one have pics and info. on putting an olds 455 in a third gen. firebird
Old Aug 25, 2007 | 09:52 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: olds engine in a f body bird
You need to search the engine swap forum. There are plenty of pics of Olds engines in third gens.
The 455 is a little wider than the small blocks (307/350) that are pictured. You will probably have to clearance or modify the A/C box.
Good luck!
Old Sep 3, 2007 | 09:26 PM
badinfluenceRS's Avatar
Car: 1994 Trans Am - 1992 Firebird
Engine: LT1 5.7 V8 - 3.1 V6
Axle/Gears: 3.42 / LSD
search my recent threads started...
I had a olds 307 in a 87 bird
It fit, and I would say that a 455 would fit because there was lots of extra space w/ a modified ac/heater box
Old Sep 4, 2007 | 03:29 PM
naterman35's Avatar
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
The car that badinfluenceRS is talking about is this... It is a 307 olds not quite a 455 which is wider. But if youd like the 307 ill Sell you both engine and tranny for it.
colton_carlson
Mar 8, 2019 12:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
Exxon Limited
Aug 9, 2015 08:13 PM
