bbc hooker headers
Old Sep 6, 2007 | 11:16 AM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
bbc hooker headers
i just finished bolting the passenger side header up on my big block swap.I'm counting 5 places where my hand is bleeding,roughest set of headers i've ever installed!My hats off to you guys that have done this
Old Sep 6, 2007 | 01:17 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: bbc hooker headers
As I mention in other posts, Hooker are the cheapest swap headers and the worst fitting.
Back when I first used them in my BBC swap, I had a 7 quart pan. It took me 9 hours to finally get them installed.
I now use large tube Ed quay headers. Each tube is separate and they use a slip on collector. It took a bit to install them the first time because of clearance issues with the large tubes but now I can take them off in about 1/2 an hour. Putting them back in is a little more tricky because you need to know which tube to install first. Still a lot easier than the Hookers.
Hooker swap headers are less than $400. Any high quality swap header, expect to pay $1000+.
Old Sep 6, 2007 | 04:52 PM
craig's Avatar
Car: 86 camaro
i'll have to go check out there site, i can't imagine a bigger tube in there!
Old Sep 6, 2007 | 07:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Not from Hooker. The Supercomp headers are a BBC street header. With the 1-7/8" primaries and 3" collectors, they're not very good for anything bigger than a mild 454. As you go up in tube size, the cost of the headers drastically increases also.
My headers have 2-1/4" tubes and yes they are a very tight fit and they have 4" collectors. I run a dual 4" exhaust through Magnaflow race mufflers which exit in front of the rear wheels. It's a race only exhaust system.
The best fitting headers are custom built. One set specifically built to fit your engine and chassis.
Old Mar 2, 2011 | 05:12 AM
Seri's Avatar
Car: 91 Camaro
Engine: 396
Transmission: TH-400
Axle/Gears: 3.70
i know this is a really old post however i was wondering if the hooker headers would be ok for a 396 bored 30 over with an 8-71 roots blower? This will be a street car and see the strip a few times just for kicks.
Old Mar 2, 2011 | 07:07 AM
AlkyIROC's Avatar
Car: 87 IROC L98
With the added boost from the big blower, I'd say the headers will probably be too small.
Old Mar 18, 2011 | 01:39 PM
mongo136's Avatar
Car: 89 camaro rs
Engine: 468 bbc
Transmission: powerglide
Axle/Gears: 373 S-60
I set my bbc in for fitment before paint, the headers were tricky(hookers) set them in then set the engine into them i found this to be the only way. I just ordered a PA Racing K-member hoping that will make it a little easier. My bbc (468) isnt a blower motor, its about 13:1 compression. Any opinions on tube size, should I sell and go bigger? hookers are 1-7/8
Old Mar 18, 2011 | 02:16 PM
1BADRZ28's Avatar
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
My Ed Quay driver side slides in from the bottom no problem. The passenger side is sectioned but goes in just as easily from the bottom too. These are 2 1/4 stepped to 2 3/8ths
Old Mar 18, 2011 | 06:08 PM
The Devastator's Avatar
Car: 1992 Camaro RS
Engine: 8.0:1 454/Mild Hyd roller/Accel DFI
Transmission: WC T5
Axle/Gears: Stock 1992 open 7.5" 2.73 ratio
I've had my 454 out about 5 times since the hookers. Me and my friend have gotten pretty proficient at it lol. You just gotta learn the order of removal. That tubular K member helped alot too.
Old Mar 18, 2011 | 09:52 PM
AlkyIROC's Avatar
Car: 87 IROC L98
There's a large tube header set with collector mufflers currently available on Ebay. Price is very reasonable considering what you're bidding on. Search for camaro bbc headers. If I didn't already have a large tube header, I would have bought them.
redformula88
Oct 14, 2015 06:08 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
hdis2002
Sep 8, 2015 02:52 PM
