L69 to a 350- need advice
Old Sep 9, 2007 | 10:50 AM
855speed's Avatar
Car: 1985 Iroc, t-top
Engine: 5.0L HO L69
Transmission: Mt 5 speed
Axle/Gears: 3.73 Non Posi, Alum Drums
I have a L69 1985 IROC, with a T5 trans. Motor started smoking when I bought it and put it in the garage 1 year ago. Finally pulled the motor and I bought a almost new Good-wrench 350 crate motor. (Factory 260HP.. doubtful)It has 76cc chambers. I want to replace the cam and heads to get more power. I already have a 3" exhaust on the car, with headers (Edelbrock), and modified HEI system. Also has a Edelbrock manifold and carb.
I was thinking Vortec (64cc) heads and intake would be a good addition with a cam. I realize this isn't the best base motor but its what I have. What would you guys do? Primarily used for street, NO racing.
Old Sep 9, 2007 | 01:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
With Vortecs, you'd need different rocker arms as well. If you're going to go that way, seriously consider this kit http://www.sdparts.com/product/SD806...RPMAirGap.aspx - has everything you need to install the heads. But, will require a squarebore carb. This one http://www.sdparts.com/product/SD806...merIntake.aspx is a little more on the mild side, and would allow you to use your current carb and ignition - not a bad idea for the street, just not as good as a double pumper carb for rowing through the gears.
A mild cam like a Comp XE262, or XE268 if you go with the RPM intake, would compliment them well.
On the other hand, your current heads rebuilt, basic port clean-up, new valve springs & retainers, and 1.94" intake valves would raise compression with the dished pistons the Goodwrench has, you could use your current intake, carb, ignition, etc., and would cost you a lot less than going Vortec for very little sacrifice in performance.
Old Sep 9, 2007 | 04:21 PM
855speed's Avatar
Engine: 5.0L HO L69
Re: L69 to a 350- need advice
Motor has about 2000 miles on it, and the heads are bad casting numbers(Smoggers that flow crap). I really want to be about 300 horse at the crank.
Old Sep 9, 2007 | 07:42 PM
five7kid's Avatar
Sorry, I meant work over your L69 305 heads. I know the crate heads are boat anchors. The L69 heads with the work I talked about, and even the XE262 cam will put you in the 300 crank HP range.
Old Sep 9, 2007 | 08:02 PM
855speed's Avatar
Engine: 5.0L HO L69
What do you think of these heads?
http://store.summitracing.com/partde...5&autoview=sku
These and a cam. These heads might be a little more than a local rebuild, but most rebuilders around here stink. With these I can use the parts I already have.
My intake is a performer (Edelbrock)
Old Sep 9, 2007 | 08:43 PM
five7kid's Avatar
They'll raise your compression over the crate heads, but not as much as the L69 had.
The Vortecs would produce better power.
PurelyPMD
May 5, 2016 04:57 PM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
